[SOLD] 1971 Dart Swinger rust free
MoJoe
Member
Michigan
Rating - 0%
0   0   0
1971 Dodge Dart Swinger
Located in Hamilton Michigan
Asking $4200
Arizona car, absolutely no rust. Body has been sanded and partially in epoxy primer. Subframe connectors and mini tubbed.
8 3/4 rear end narrowed
55.25” wide axle flange to flange
Stock 57 1/8”
Large bolt pattern factory axles, narrowed with factory tapered roller bearings, 4.5” bolt pattern and drum rear brakes. Currently open 3:23 741 center section.
Later model factory disc brakes, spindles and k-frame with better spool type engine mounts. Set up for small block. Originally was slant six.
Power steering, manual brakes, air conditioning.
Brand new fuel tank, straps and sending unit still in boxes.
Absolutely the most solid Dart I’ve ever had or seen. You will save hundreds or thousands in metal repair and body work starting with this car.
I also have a couple 360’s or 440’s each with transmissions I would sell with the car if interested.
Sold it $3500. Four people made $3500 offers so I figured that must be a sign. There’s still good deals out there and I thought you all would appreciate knowing what it sold for as we can always see what people are asking but not what they actually sold it for. Thanks for looking.
