Well I haven't be able to work to much on the car because I've been tasked with assistance in putting the body panels back on a 31 Chevy.
I did get the fuel cell and welded the hole shut in the trunk floor in preparation for mounting the tank.
Needless to say it was a good experience in filling large gaps and welding from thick to thin metal.
When the frame off resto happens I will replace the whole panel with a flat sheet of metal.
Also swapped the steering wheel over and test fitted it to make sure the steering wheel adapter worked and didn't set the wheel out to far.
