[WANTED] 1971 Demon Parking Brake Warning Light Switch
salami340
Rating - 0%
0   0   0
I'm looking for an original working switch for the parking brake warning light that works or if there is an aftermarket switch that will work but I could not find anything in my Googling. The only switches I could find on eBay are attached to the entire assembly and I only need a switch. I wouldn't mind buying the entire assembly just for the switch as long as it wasn't too expensive and the switch was working. The first pic I attached is the empty bracket I think.
Also side question I assume the blue wire in the second pic is what plugs into the switch if I had one?
It is basically a door switch.
Red is where the single SAE terminal plugs into
Green is where the outer part contacts the inner part making a path to ground when the e brake is pulled out
Looks like @Oldmanmopar has you covered
