I'm looking for an original working switch for the parking brake warning light that works or if there is an aftermarket switch that will work but I could not find anything in my Googling. The only switches I could find on eBay are attached to the entire assembly and I only need a switch. I wouldn't mind buying the entire assembly just for the switch as long as it wasn't too expensive and the switch was working. The first pic I attached is the empty bracket I think.
Also side question I assume the blue wire in the second pic is what plugs into the switch if I had one?
