1971 DEMON WITH POWER BRAKES......WHERE DOES THE SPEEDO CABLE GO?
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
Trying to figure out if the speedo. cable passes to the driver side or passenger side of the booster's vertical support strut on it's way down the firewall.
Thanks FABO
The cable should have a cone shaped rubber grommet on it and you should be able to tell which hole it goes into by the OD of said grommet.
Thanks....Got the hole figured out, but the lower booster support strut has to be navigated. Looks like the feedback from this thread has me pointing in the right direction.
Thanks All. :thumbsup:
