[FOR SALE] 1971 dodge dart
el5dart
memphis, tn.
for sale is my 1971 dodge dart.
$16000.00
i have over 20k invested not even including the many hours of labor. and it could use more to make it a show winner. i nut and bolted this from scratch. but in reality are they ever a finished project?? theres always one more thing you wanna do to them.
motor is 318 with bullet cam and x heads, 68 hipo exhaust, edelbrock 4 bbl. , tti x pipe exhaust system, dr. diff new front suspension, 73 disk brakes, spool k member and trans cross member, 4 speed with b body pistol grip, rallye dash, dr. diff 8 3/4 housing and axles and rear drum brakes, cop car rims, new bf goodrich radial t/a tires, new gas tank, new gas lines, new brake lines, hydraulic clutch, mcleoud clutch and pressure plate , tuff wheel, new carpet, etc.. i could go on and on. best to see and drive in person.
car was originaly butterscotch and could use a repaint.
located in memphis tn.
things it needs:
body seam sealed in corners of rear glass
rear main seal from sitting on an incline.
rear quarter glass adjusted.
ac looked at and charged.
needs original sending unit. its the only gauge on dash not working.
you can hop in it and cruise it though.
power steering manual brakes and a/c all there needs charged etc. does have all new orings on a/c. just needs one wire under hood to compressor and charged as far as i know
no i put 74 doors on a 71 cuz i don’t like the cigarrette windows so much. and looks good IMO
side marker lights verify 1971
i know where original doors are if you just have to have them
rallye dash is custom to this car too.
this is not an h code car. i took the liberty of a little tweaking here and there.
245/60r15 tires on rear
motor and trans are not numbers matching. but all numbers on body and dash are matching
car has about 900 miles on it since i built it. back tires have 20 or so miles on them. dated feb 24
if you cut out an a/c car firewall section and overlay it on a non ac car trace it and cut it out perfectly you cannot tell that it was not an a/c car. all a/c components on the firewall will bolt right up
You're saying it's not a factory AC car?
Is it a factory 4 speed car?
