1971 duster 100% done..or atleast i think
Looks great! Do you have any pics of what you did for the rear hood pins I could see? I'm looking for under the hood shots of 'em.
here is how i mounted the striker pads on the hood. As you can see with the hood pins i have a nut on top that sandwhiches the lanyard then another nut which sandwhiches the hood pin to the body with a third nut. I tried using springs on the pins so that when i took the R-keys off the hood would lift up a little to make it easy to lift the hood off. Unfortunately the springs were either too stiff or to light so i went with a rubber hose to get the hood the ideal height.
