[SOLD] 1971 Duster 408 Stroker 4-speed full rotisserie restoration
Charger727
Member
Eau Claire, WI
Rating - 0%
0   0   0
Beautifully restored 1971 Plymouth Duster equipped with a 408 cubic inch stroker engine. Underwent a complete rotisserie restoration in 2011. Originally a A51 Duster Twister special package car 318 2bbl 3-speed manual transmission. Asking $32K - I know that's a lot for a Duster, but this one was built for a lot more than what I'm asking. Car is is Wisconsin.
If you have any questions don't hesitate to email me. More pictures are available upon request.
ENGINE -
360 small-block, stroked to 408 cubic inches
Eagle H-beam connecting rods
Eagle forged crank
Hughes HTL4248AS solid lifter cam,
Diamond pistons
Indy/RHS heads prepped by IMM Engines
Kevko 5qt oil pan
AED 750HP double pumper carburetor
TTI exhaust, ceramic coated headers with stainless tips, stainless magnaflow mufflers
Edelbrock Performer RPM Air-gap intake manifold
FBO ignition system, (no ballast resistor) with adjustable rev limiter
Thermostatically controlled twin Spahl cooling fans
March serpentine pulleys and belt, Quality Power billet 150 Amp alternator.
Dyno results of 503 HP, 520 ft lbs torque!!!
BODY -
Solid, fully-restored on rotisserie with frame connectors for added rigidity
Original floors, rockers, fenders, doors
Only minor bodywork was required in the rear quarters ( they are mostly original)
Only the bottom portion of the trunk spare tire well needed to be replaced
Painted in correct EV4 Hemi Orange in base-clear top to bottom
New bumpers front & rear
Fully restored original shark-tooth grille
1971 gull-wing rear spoiler
Spoilers by Randy front spoiler
New fuel tank
New windshield and side glass, (original rear glass in excellent condition)
All new body gaskets and weatherstriping
Stainless trim restored
SUSPENSION & DRIVETRAIN
1973 front K-frame with spool engine mounts
All suspension components restored with new bushing and ball-joints
Flaming River fast ratio steering box
Front & Rear heavy duty sway bars
Bilstein shocks all around
Wilwood front disc brakes, stainless brake lines
Narrowed Mopar 8 3/4 rear with 489 case with clutch-style sure-grip and 3.55 gear set.
Relocated leaf springs to allow nice big tires - 275-60 rear, 215-65 front
Moser 30-spline axles.
MB "old school" wheels 15x7 front, 15x8 rear
Billet flywheel with Centerforce clutch
Completely rebuilt 833 4-speed transmission
Driveshaft loop
INTERIOR
New Legendary upholstery, including new inner seat foam, new door panels, headliner
New cut-pile carpeting
New dash pad
Fully restored heater box
RetroSound stereo with AUX, USB, SD card ports and Pioneer 400W Amp, Alpine speakers
Hand carved real-wood pistol grip Hurst shifter with dash mounted adjustable shift light
New Vintage Instruments in custom dash cluster, all electronic gauges including speedometer
Tuff wheel steering wheel
Dynamat sound & heat insulation
3-point retractable front seat belts
Modern-style relay system headlights - bright! no old-car dim headlight issues
ENGINE -
Eagle forged crank
Diamond pistons
Kevko 5qt oil pan
BODY -
New fuel tank
Driveshaft loop
INTERIOR
New dash pad
View attachment 1715173330 View attachment 1715173331 View attachment 1715173332 View attachment 1715173333 View attachment 1715173334 View attachment 1715173335 View attachment 1715173336 View attachment 1715173337 View attachment 1715173338
If you don't mind, who is the manufacturer of "MB wheels"? Beautiful car, good luck with sale.
Not sure who the parent company is, but if you go to Summit, Jegs, Discount Tire, they all offer MB as a brand with lots of different styles. I liked the look of these "old school" rims and they weren't that common a couple years ago - now I see more of them around
Thanks for info, they look great on your car.
WOW thats a beautiful clean car. I have $37K into my duster, and i dont care. Its mine and i built it this way, just like you did. Dont let someone dictate what your car is worth. Let them try and build one as nice as yours and they will know what it costs.
GLWS.
