snowcrane2005
- Joined
- May 21, 2009
- Messages
- 70
- Reaction score
- 4
I am trying to do research on fender mounted turn signals for a 1971 duster but not getting much for a clear answer. Wondering if they are the same as a 1971 cuda?
Yes they are exactly the same as a 71 Cuda including the lens, socket, housing and cable (pigtail)I am trying to do research on fender mounted turn signals for a 1971 duster but not getting much for a clear answer. Wondering if they are the same as a 1971 cuda?
Not to be repeated myself but are you sure they are the same? So if I order a complete set for a 71 cuda that need to be painted those are the right ones?Yes they are exactly the same as a 71 Cuda including the lens, socket, housing and cable (pigtail)
BTW i am only speaking for original equipment NOT REPO or REMAKES, i do not know what they are designed after or fit! I have had numerous 71 Dusters and a few 71 Cudas with them on and still have a 71 Twister here with them on from the factory and yes they are the same part numbers as a 71 Cuda and they get painted, would you like me to post a pic from the 71 Chrysler parts book? If so just let me know and i can do that for you.Not to be repeated myself but are you sure they are the same? So if I order a complete set for a 71 cuda that need to be painted those are the right ones?
Nope that works for me thanks so much for the infoBTW i am only speaking for original equipment NOT REPO or REMAKES, i do not know what they are designed after or fit! I have had numerous 71 Dusters and a few 71 Cudas with them on and still have a 71 Twister here with them on from the factory and yes they are the same part numbers as a 71 Cuda and they get painted, would you like me to post a pic from the 71 Chrysler parts book? If so just let me know and i can do that for you.
