[SOLD] 1971 Duster Super Pro drag car
terrys5746
Member
Rochester, Mn
Rating - 0%
0   0   0
1971 Plymouth Duster Super Pro drag car
Full roll cage, ladder bars, coil overs , frame narrowed, wheel tubes, narrowed Dana 60 rearend, 14 x 32 slicks, 14in wide wheels, 8 gallon fuel cell, 4 wheel disk brakes, Turbo Action 904 trans with Turbo Action converter, weighs 2800 lbs, delay box, Weld wheels, fiber glass hood / trunk / bumpers, MSD ignition, 750 Holly double pumper, electric water pump drive, aluminum radiator,
Car comes with 2 motors.
The motor in the car is a 340 and runs 11.60’s in the ¼ mi. steel rods and crank, stock pistons, balanced, DC hydraulic hemi grind cam, ported TA heads, aluminum intake
The additional motor is a 340 and runs 10.60’s in the ¼ mi.
Steel rods and crank, Ross 12 to 1 pistons, roller cam. Ported W2 heads, stainless steel valves, titanium valve spring retainers,Norris stainless steel roller tip rocker arms,Holley Aluminum intake. $9,500
Rochester, Mn
Rochester, Mn
:worthles:
If that car was closer I would probably try to buy it. It is screaming for a 600 HP stroker instead of that 340.
