PFDBat2
New Member
I have a 1971 Duster I purchased 2 month ago. The water temp gauge did not work, I have done the following:
Any ideas
- Replaced the sensor (twice)
- Replaced the Circuit board
- Replaced the gauge
- Replaced the voltage reducer (twice)
- Checked continuity From engine to Gauge
- Grounded the sensor not install, heated with lighter gauge worked
- Installed ground wire from bolt on intake to master cylinder
- Wrapped the sensor (installed) with wire to negative post on battery
- Water comes out or the hole the sensor replaced
Any ideas
