[SOLD] 1972 360 new short block
moparraceman
mansfield ohio
1972 360 block, checked ,cleaned , bored,honed,align honed,rods resized with new arp bolts .crank ground .010 - .010 complete assembly balanced .have new KB pistons hyper ,10.5-1 new rings,rod-main bearing ,cam bearings,brass freeze plugs ,double roller timing chain . also oil pump and shaft and gear front crank balancer and new flex plate also balanced with assembly . over $2300. invested $1500. great deal my project didnt happen my loss your gain
What is the current bore size? Were the axes of the bores corrected relative to the main journal? Was the block squared? (deck relative to mains and bore). Thanks.
BLOCK BORED .070 GIVES 372 CU IN block was line honed ,bored and honed , was not decked. pistons i have with .039 fel pro #1008 head gasket leaves .011 and gives 10.5-1 comp ratio. thanks
