1972 dart 4 door interior
Chub380
Montana
Just curious if anyone on here has a 1972 Dodge Dart 4 door I have an interior question
I do not have one, but what is your question?
It’s my daughters car and I’m trying to find someone who has one to figure out how many headliner bows it should have some catalogs say 4 others say 5 so I really don’t know what to order as the back portion was already messed with when we bought the car. There are 3 still inside the headliner from front to back with the last one inside being at the dome light. The last one has some 90 degree bends on it. I’ll post a pic it will make more sense
If you blow up the pic you can see a pocket with three holes in it between the very back bow and the bow at the dome light. I’m not sure if one should have been there?
No one has any idea on this?
I have a 72 dart 4 door that I am parting out. I have all of the headliner bows. The back one is bigger than the rest and it has 3 or 4 wire clips about 6-8 inches long that clip on the back hoop to the rear window frame. This keep the hoop in the right place. I didn't see those in your picture. If that helps. I you are missing any thing I have all the hoops and the wire clips for the back hoop.
Scott
The back one is there and has those little wires holding it. They are there just hard to see through the fiberglass. Counting that back one how many total does yours have?
I think there 3 or 4 hoops total. I wont be home till tonight.
I think there 3 or 4 hoops total. I wont be home till tonight. What parts are you looking for I have several left. Front Spit bench seat with center arm rest, steering wheel and column, Front and Rear Glass and Stainless Trim, stock wheels and tires, entire A/C Heating system less condensor coil, Rear end, Dash instrument gauge/speedo cluster. Trunk Lid, Gas Tank, wiring harness. Let me know if there is something you need that I might have.
Sorry fellas this is not a sale/wanted thread. Thanks
Ok I appreciate you checking I’m really struggling with some say 5 if it’s an early 72 four if it’s later I’ll have to look at the vin tonight. Thanks again for checking
