For Sale:
A very solid original sheet metal 1972 Dodge Demon, originaly a 340 H code car with a (3 or 4 speed) manual transmission ( clutch pedals are still in the car) ... It now has a built 360, with a set of worked 340 X heads... The trans is a 904 with a turbo action J 8 inch converter (4500-4800 Stahl)... Rear is an 8 3/4 with a new Richmand 4:10 gear set, and a clutch type suregrip diff... The frame has been tied together with weld in frame connectors...
I bought this car out of North Carolina 3 summers ago. It has been in lower central PA since... I was told by the previous two owners, that the car was this color combo... White, with blue interior... There is no fender tag or build sheet to back this up...
Car is very quick, it has run 7.13 at 95 mph in the 1/8 mile... That is through the mufflers right off the street...
MISC:
4 point cage
3 inch spring relocation kit installed
rechrome front and rear staight bumpers
weld racing aluma star wheels
strange street strip axles, green bearings screw in studs
line locs
turbo action shifter
M/T ET Street 28 X 12.5 Tires
MSD ignition
2800lb Super Stock leaf springs
US Tool driveshaft loop
Adjustable pinion snubber
New MP clutch fan
X-pipe flow master exhaust
Price $16.500
MISC:
4 point cage
line locs
MSD ignition
New MP clutch fan
Price $16.500
