G Gennaro Member Joined Jul 13, 2018 Messages 20 Reaction score 1 Location PA Rating - 0% 0 0 0 Oct 14, 2018 #1 Contact seller in search of a driveshaft or maybe even just a slip yoke for a 3 speed with 8 3/4 rear. From research I’ve done needs to be 48.89 center to center. Thanks
Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,415 Reaction score 5,290 Location PA Rating - 100% 4 0 0 Oct 14, 2018 #2 Same slip yoke for a 904 automatic if that helps your search?
AJ/FormS 68 Formua-S fastback clone 367/A833/GVod/3.55s Joined Jan 19, 2014 Messages 25,083 Reaction score 12,432 Location South-Central Manitoba,Canada, 900ftelevation Rating - 100% 1 0 0 Oct 15, 2018 #3 I thought the A230 had a 727 sized yoke?
Moparparts Well-Known Member Joined Nov 15, 2010 Messages 3,919 Reaction score 213 Location PA Rating - 100% 274 0 0 Oct 22, 2018 #4 What is the spline count on your trans output shaft?
blewbyu FABO Gold Member FABO Gold Member Joined Jul 14, 2010 Messages 3,195 Reaction score 1,200 Location Florida Rating - 97.7% 41 1 1 Oct 23, 2018 #5 I have a 48.50 if that helps. I will check for a 48.89
G Gennaro Member Joined Jul 13, 2018 Messages 20 Reaction score 1 Location PA Rating - 0% 0 0 0 Oct 23, 2018 #6 blewbyu said: I have a 48.50 if that helps. I will check for a 48.89 Click to expand... 48.50 would probably work. How much are you asking?
G Gennaro Member Joined Jul 13, 2018 Messages 20 Reaction score 1 Location PA Rating - 0% 0 0 0 Oct 23, 2018 #7 Moparparts said: What is the spline count on your trans output shaft? Click to expand... I have to count. Will do it tonight
blewbyu FABO Gold Member FABO Gold Member Joined Jul 14, 2010 Messages 3,195 Reaction score 1,200 Location Florida Rating - 97.7% 41 1 1 Oct 23, 2018 #8 $100.00 for the shaft and if you need the 904 slip yoke another $25.00 plus shipping
G Gennaro Member Joined Jul 13, 2018 Messages 20 Reaction score 1 Location PA Rating - 0% 0 0 0 Oct 23, 2018 #9 blewbyu said: $100.00 for the shaft and if you need the 904 slip yoke another $25.00 plus shipping Click to expand... Can you give me an idea on shipping to 18424
blewbyu FABO Gold Member FABO Gold Member Joined Jul 14, 2010 Messages 3,195 Reaction score 1,200 Location Florida Rating - 97.7% 41 1 1 Oct 23, 2018 #10 $35.00
Mtrhead Ace of Spades ♠️ Joined Sep 19, 2018 Messages 4,668 Reaction score 3,301 Location S.C. Rating - 100% 32 0 0 Oct 25, 2018 #11 I got a 49.30 shaft with the right time on it can sell and ship all for $110
Mtrhead Ace of Spades ♠️ Joined Sep 19, 2018 Messages 4,668 Reaction score 3,301 Location S.C. Rating - 100% 32 0 0 Oct 25, 2018 #12 It has the right 29 spline 904 yoke installed
Mtrhead Ace of Spades ♠️ Joined Sep 19, 2018 Messages 4,668 Reaction score 3,301 Location S.C. Rating - 100% 32 0 0 Oct 25, 2018 #13 Here is pic
