WymanV
..you said "member"...
Hey all,
The quick question is will my 1972 Duster 340 engine harness wi/electronic ignition essentially "plug & play" fit in a 1971 Duster 340 with rallye dash or do I have some rewiring to do to make it work?
The longer backstory goes like this: The car in question is a 1972 Duster 340/4 speed. I've replaced the dashboard with one from a 1968 Barracuda (cheap and available) which has been brought up to 1971 specs (other than the extra "cigar" lighter, which I can certainly use as another charging port, etc.) and the dash harness I scored is from a 1971 Duster 340 with rallye dash and judging by the presence of the dashboard mounted reverse light in the harness, a 4 speed car as well. So the question is can I just plug that engine harness into the rallye cluster harness or do I have to make changes to make it work? Now's the time to do it if I have to as I'm up to my ears in modifying and reconditioning the harnesses to meet my needs and the engine's out.
Thanks
Ken
Thanks
Ken
