1972 Duster mini tub 440 727 8 3/4
slick11x
Member
Here are some pictures of my 72 Duster mini tub/ spring relocation with N-50's, 15x10's
What kind of master cyclinder did you use? Is it set-up disc-drum?
Its been a few years, think its an 84 dodge pick up .It has 4 piston kelsey Hayse with 11" x2.5 in the rear. Think Mancini Racing has all parts needed to convert this master over. Stops fine for manual brakes. Slick
That looks just like the one I got from Mancini. It is made buy strange and is super light.
What are you using as for as prop valve or residual valves go with the disc drum set up?
Stock proportioning valve, no residual valve.Yes it is very light.Pushrod needed to be modifyed,since I did this about 18 years ago you can now buy whats needed from Mancini racing.
Lookin' very nice. You did it right and kept the hinges. :cheers: The dumbass PO that did my Demon removed all that stuff. ](*,)
Wylde1.
