1972 duster
72dustervs
Winchester, Kentucky
I have a 72 duster that had power drum front brakes , I am converting to disk from a 75 dart , rotors an control arms , so can I just get a new metering valve to convert to disk or do I need a new booster an master cylinder swap ?? And is there a direct replacement for a booster ?
Use your booster if its good, get a disc/drum master cylinder for it. discs require more fluid volume, that's why the reservoir for the front is larger on disc masters. You'll also need the disc/drum combination valve. Use the parts from the '75 Dart or new ones for a '75.
