'72 Duster
360ci, 727 Torque Flight, 8 3/4 Sure Grip rear end.
The motor runs strong. Has a slight ticking on the left lifters. Needs a bigger radiator. Sometimes gets a little hot sitting in traffic. Has a 3 core installed. Has an Edelbrock intake and 4bbl carb, Hooker Comp. headers, holly electric fuel pump.
The transmission leaks a little bit. Has a performance shift kit and a B&M rachet shifter intstalled.
The rear end is flawless. 3.91 gears w/ Auburn posi.
The torsion bars need to be upgraded and the front left tire rubs when making a left turn.
There are some rust areas on the car, but a little work can fix that.
If you have any questions please e-mail me at moparpower72@comcast.net
$7000 obo. Im pretty flexible
