Mopar Moo
Member
1972 Plymouth Valiant. $1500 or best offer. Located in Hampton VA 23669. 225 Slant 6 engine, power steering, auto transmission. Registered Daily Driver in running condition, but needs TLC. Inspection good until March 2019. Odometer reads 78,000+ miles. We're not original owners, so we're not sure how many times odometer has turned over 100k.
This is a registered and running, 46 year old car that needs someone with some mechanical experience. I have a few spare parts, original window sticker and build sheet. Hood is autographed by Ed Miller - 1967 NHRA Super Stock World Champion.
Since purchasing it in late 2013 we have installed:
Used rear end, Air shocks, 2 new tires, Windshield, NOS factory electronic ignition (installed by Ed Miller), Distributor, Voltage regulator, Alternator, Plugs & wires, Battery (only 1 year old), Used heater controls, Heater control valve, Carpet (Needs cleaning), Master cylinder, Driver side wheel cylinder, Brake shoes (turned drums), Wheel bearings (front), Ball joints, Steering gear & pitman arm, Idler arm, Driver side Strut rod bushings, Fuel pump, Radiator, All hoses and vacuum lines, Fan belt, Speedo cable, Repaired hole in spare tire well, Cleaned front floorboards and trunk floor, applied rust inhibitor and painted, Painted exterior after accident in 2014.
