BJDEALER
Are they the KH brakes? They are SBP. I am pretty sure they will bolt right on to my car? 66 cuda. Do i have to change the spindles? ball joints? thanks
No, you need the hubs with the disc conversion. Why not just put the '66 drum brake setup back on the '72 Swinger to move it around?Is it possible for the guy to take the brakes off and leave the hubs? The guy wants make sure he can still move the car.
If you want to use a power brake setup from the donor car, get it complete with all the brackets and linkage. If the donor master cylinder is still good, you can use it, if not, get a new one for a power brake system. Your '66 Barracuda is only a single braking system so you'll need both lines and the proportioning valve. I'd swap the whole thing, lines, hose, valve, etc. but you should be able to reuse your old lines that run across the firewall with only minor modifications if you want. You'll probably have to adapt a fitting here or there and rebend some of the lines anyway. If all the caliper pistons are free and the pads are good, sure, bolt it on and run it. If you're going to change the rotors, I'd install new pads.Thanks Mark. I have made a deal with the guy for some drums i bought off another guy just to put on the 72 disc car. The guy just wants a roller so he can move it still. I plan on getting the discs and all the hydralics. It is a powerbrake car. Can i use the master cylinder too in my car? Do i need just the brake lines from the MC to the proportioning valve? Do i need any other brake lines or will my existing stuff work? The shoes on the brakes look brand new so i am thinking about just trying the brakes the way they are and not getting new calipers right away. I probably will get new rotors though. Man i am glad i finally found some KH discs they sell like hot cakes around here LOL.
