1972 swinger turbo gen 3 hemi build
Forced Induction Mopar
  1. kevin1969
    kevin1969 Well-Known Member
    72
    9
    Jan 9, 2015
    keystone heights fl
    Local Time:
    5:17 AM
    ok I sold my other set up and four door body now onto a 1972 2 door swinger. I'm running a stock 5.7 hemi with a 6.1 cam and injectors. I'm running a Fast 87mm throttle body cable driven with a EFI source maga squirt 3 gold box. I made my own hot side using ram manifolds because of the tight quarters in the A body. I switched to manual rack and pinion for clearance issues with the stock box. I have a turbonetics 72mm turbo and turbo smart wastegate all 3" with a large front mount intercooler all is still in work. Here are some pictures.
  2. kevin1969
    72
    9
    Jan 9, 2015
    keystone heights fl
    Local Time:
    5:17 AM
    Pics
  3. kevin1969
    72
    9
    Jan 9, 2015
    keystone heights fl
    Local Time:
    5:17 AM
    I used a old motor for moch ups
  4. kevin1969
    72
    9
    Jan 9, 2015
    keystone heights fl
    Local Time:
    5:17 AM
    The plan is to keep A/C also should work out I'll be mocking that up this week as well as the steering.
  5. Evan Dutch
    Evan Dutch Well-Known Member
    554
    147
    May 11, 2016
    monroe north carolina
    Local Time:
    5:17 AM
  6. Dustert73
    Dustert73 Stripping bolts since ‘10
    758
    55
    Dec 22, 2014
    Ohio
    Local Time:
    5:17 AM
    Awesome
  7. subcom
    subcom Well-Known Member
    1,251
    414
    Sep 17, 2010
    South Florida
    Local Time:
    5:17 AM
    Nice! Which R&P setup are you using?
  8. kevin1969
    72
    9
    Jan 9, 2015
    keystone heights fl
    Local Time:
    5:17 AM
    R&P set up?
  9. subcom
    1,251
    414
    Sep 17, 2010
    South Florida
    Local Time:
    5:17 AM
    Sorry. Rack and pinion.
  10. kevin1969
    72
    9
    Jan 9, 2015
    keystone heights fl
    Local Time:
    5:17 AM
    Oh lol sorry mustang 2 manual going to try the flipped ball joint trick and run it front steer. We'll see how it turns out
  11. junior636
    junior636 Well-Known Member
    586
    31
    Oct 28, 2009
    Grand Rapids, MI
    Local Time:
    4:17 AM
    I'm doing a similar build, why didn't you just flip the manifolds forward? Where's the exhuast going to go now?
    • Agree Agree x 1
    • kevin1969
      72
      9
      Jan 9, 2015
      keystone heights fl
      Local Time:
      5:17 AM
      The hemi manifolds can't be flipped like the la small blocks. You have to swap heads and wasn't to sure of possible oiling issues by doing that. Also flipped manifolds would not allow the stock accessories I have to fit this would cause a whole new set of issues. The pictures show how the exhaust is routed to the turbo.
    • junior636
      586
      31
      Oct 28, 2009
      Grand Rapids, MI
      Local Time:
      4:17 AM
      You can flip them, you just have to drill and tap the heads for the center ports. I was asking where you were going to go with the exhuast out of the turbo.
    • kevin1969
      72
      9
      Jan 9, 2015
      keystone heights fl
      Local Time:
      5:17 AM
      Yes I did notice a boss to drill but was unsure, I have a junk set of heads I was going to try with but decided to go the other way because I want to run the A/C and car style intake. The down pipe will kick out the wheel well and run out that way I will post pictures when I get it mocked up. I'm doing the four link and mini tub this weekend and might work on the rest of the exhaust too.
    • turbofreek
      turbofreek batcrap crazy racing team
      1,202
      325
      Mar 2, 2009
      kansas city, mo
      Local Time:
      4:17 AM
      im with junior on this one. could have just flipped the log outlet strait up to the turbo inlet. would have left room for ac as well.
    • kevin1969
      72
      9
      Jan 9, 2015
      keystone heights fl
      Local Time:
      5:17 AM
      That's cool. But if you've built a turbo setup on a hemi in an a body post some pics the right manifold runs right into the alternator if you flip it. The other option is truck accessories this puts the alternator and compressor in the way of the intake. Then that still leaves you with getting the driver bank up to the turbo.
    • turbofreek
      1,202
      325
      Mar 2, 2009
      kansas city, mo
      Local Time:
      4:17 AM
      because nobody uses the car front in a body swaps. most have custom covers or truck covers cut down and a relocated alt mount. i k ow there is room to run a log forward. cut the flange of and run a direct 90 upwards. i know i was gonna do this very thing behind my motor plate. but i prefer3d to no have it all cluttered up over the pass valve cover.
    • kevin1969
      72
      9
      Jan 9, 2015
      keystone heights fl
      Local Time:
      5:17 AM
      Well it's just my preference I guess, I don't feel there will be much difference with clutter either way there would be a pipe running up there either a down pipe or in this case a supply not to mention you still have to route your driver supply. And in my opinion which is just simply that I would rather have clutter out over the fenderwell and leave room for my charge pipe and bov. The compressor and altenator all suffed on top just is not appealing to me for by build. I'm happy with how it's coming out so far.
      • Like Like x 2
      • silverfox
        silverfox Well-Known Member
        214
        11
        Nov 22, 2010
        ontario
        Local Time:
        4:17 AM
        :popcorn:
      • kevin1969
        72
        9
        Jan 9, 2015
        keystone heights fl
        Local Time:
        5:17 AM
        I did the four link tonight.
        • Like Like x 1
        • turbofreek
          1,202
          325
          Mar 2, 2009
          kansas city, mo
          Local Time:
          4:17 AM
          we are all trying to fit 20lbs of crap into a 2lb bag for sure. you like it and it works for you. thats all that matters.
        • kevin1969
          72
          9
          Jan 9, 2015
          keystone heights fl
          Local Time:
          5:17 AM
          Yeah that's a true statement the motor it's self is a tight fit!
          • Like Like x 1
          • kevin1969
            72
            9
            Jan 9, 2015
            keystone heights fl
            Local Time:
            5:17 AM
            Installed a comp engineering cage in the car today. Main hoop fit nice definitely took a lot of cutting and notching to get it all right. I also put a slight bend in the back struts to clear the back seat.
          • kevin1969
            72
            9
            Jan 9, 2015
            keystone heights fl
            Local Time:
            5:17 AM
            Here are some more pictures of my rear and fuel pump plumbing
            • Like Like x 2
            • subcom
              1,251
              414
              Sep 17, 2010
              South Florida
              Local Time:
              5:17 AM
              Looks great! Is that 4 link a kit you bought?
