Caberocks
I have read through the forum and found a few tips, but still stumped on connecting the wipers on my car. Do I need both the plastic bushing and the metal clip? The one that's detached is going from drivers side to the motor. I assume the slightly bent part of the bar goes to the wiper and the larger flat side goes to the motor? Any help would be appreciated. Heck I'm not even really sure which way to put the plastic bushing in (from which side). It doesn't help either that it's 100 degrees inside of the car either today. Thanks in advance for any help!
I'm also thinking after much cussing, once I figure it out, I should replace all of the connections. The cluster, radio and glove box are out of the car at least.
