First73Dart
Active Member
I hope this is ok. I am new to mopar products. The main issues that I want to address on this car are the following:
seller told me carb always needs to be adjusted and choke sticks. Do I replace with a brand new carb or have the carb rebuilt?
there is a leak in the power steering. I’m assuming it’s coming from the pump. The seller said he filled it every month and a half. Other than the power steering pump, what she needs changed out at the same time? Thanks
the fuel gauge doesn’t work. What are some things I can check or is it safe to assume the float went bad?
the car needs new bushings and the seller thinks lower control arms. I drove the car and didn’t notice anything with the front end or suspension. What parts usually go on these cars. I would do urethane bushings like I always did on my Volkswagens.
thanks so much for all the advice
