[FOR SALE] 1973 Dodge Dart Sport 340 parting completely out
I do not believe I have any correctly numbered 26" radiators for a 340 car.
Not sure if the windshield is good or not...It has been far too long for me to remember. The next time I am down at my garage, I will look and let you know...same goes for getting the numbers off the leaf springs.
I would like to ask a favour. I am just finishing my duster that I installed the roof skin and factory sunoof assembly into from another duster (same one in your parts car). I am just routing the drain hoses for the sunroof and cannot figure out where the front hoses drain to. they go down inside the A-pillars and from there it is a mystery. Would you be able to post a picture of the routing of the hose behind the kick/foot panel? This would be a huge help for me. I am thinking in need to drill a hole into the rocker panel below the door hinge
Probably a long shot since its been picked over, but you wouldnt happen to have the fender emblems "dart" and "sport" would you? Missing both sides. Also, need a piece of passenger side rear frame rail....about the rear-most 1.5 ft of it. Looking for a friend. It would all be shipped to 45102 in Ohio
are the taillights for sale, if so how much?
Also, i see you sold the folding seat. did you sell the trunk side folding section with it?
I'll send in PM so its easier to see your response. Thanks.
340duster: I pulled the drain tubes out while removing the sunroof and honestly have no idea how they were routed down the A-pillar.
Belvedere66: I do not have any of those emblems.
I will check and get back to you about the condition of the passenger side rear frame rail section that is wanted.
MNDuster, I do still have the folding trunk security / divider panel.
I also still have the tail lights.
I have several pairs of painted and chrome sport mirrors, however they are unavailable at the moment. They are stored 8 hours north of me and I am unsure when I will be up there next.
Still a few pieces left...
I received no notification that you had replied to this thread...
At any rate, as you can see it is still on the car and can be yours...
The rear side vinyl top trim is two pieces per side. There is the long side piece that you can see in the photo, and there is also a short piece that screws in and goes across to the rear window
$45 + shipping for both pieces and the attaching screws
do you have the trans mount crossmember the part that is welded to the floor?....I would take from torsion bar to torsion bar...torch / plasma out A-OK.
I'm in NW Ohio...43402
The parts car body/shell ( including original core support with VIN stamping, original dash w/ VIN tag, original fender tag, (3) build sheets, and left door with data sticker displaying matching VIN ) is also for sale $ 625.00 !!
I took the photos posted in this ad on 8-25-2014 !!
Location: Warren, Michigan 48089 ( I-696 & Schoenherr, easy access right off the interstate! )
List of most wanted parts that are STILL AVAILABLE:
1973 340 block with main caps - $350.00
400 engine, runs and is complete from carb to pan to original 400 exhaust manifolds (casting number 40065530-400-8; 1976-78 B-body) - $400
Big block T/F-727 transmission, works great - $275.00
B-body HP left side (2843992-1) exhaust manifold - $175.00
Sunroof assembly - $250.00
340 spool mount K-member - $150.00 (pending)
Black seat belts - $100.00
340 A-body leaf springs (left and right) with shackles and front hangers - $100.00
Vinyl top trim (missing long piece on driver side) - $75.00
Drip rail trim $25.00 (pending)
Fender w/marker light and fender mounted turn signal (passenger/right side) - $125.00
Hood - $45.00
Truck/deck lid - $65.00
Grille with headlight bezels (great shape - not the one pictured in car, it is nicer than that one.) - $75.00
Front bumper - $30.00
Plastic interior / inner wheel well covers for fold down rear seat cars - $65.00
Plastic upper door trim - $75.00
List of parts that have already been sold:
Black bucket seats, complete + tracks - Sold
A-body 8-1/4" rear axle with 3.21 gear ratio and sure-grip differential - Sold
Non-power disk brake set-up + upper control arms - Sold
Console set-up, complete with shifter + linkages + floor brackets - Sold
Floor shift p/s steering column - Sold
Sway bar lower control arms - Sold
Sway bar - Sold
120 MPH speedometer / gauge cluster - Sold
Black fold down rear seat - Sold
A/C + Heater box - Sold
Wheels with covers & tires - Sold
Front & rear rubber bumper guards / bumperettes - Sold
Fuel cap - Sold
Door lock mechanisms - Sold
Inside door lock plastic covers - Sold
Battery box - Sold
Emissions equipment - Sold
For anything not listed, simply contact me to inquire.
I will certainly ship ANY parts/pieces that you may have an interest in, you will absolutely pay the shipping.
All parts in this ad will be or already are removed from the vehicle pictured. The parts shown are the actual parts for sale.
This is an authentic 1973 Dart Sport 340 (VIN # LM29H3Bxxxxxx), however the original engine and transmission are both long gone. As you can see when I bought the car it had a 400 big block engine with 1968-70 B-body HP exhaust manifolds and a T/F-727 transmission installed (back in the late 70's/early 80's). The car ran and drove until 7-20-2014 when I decided to start parting it out.
The car was originally very loaded. It was ordered with the sunroof and the fold down rear seats, making this Dart Sport 340 a " Convertriple ". The interior was/is black with (front) bucket seats, console and the deluxe interior decor package (full woodgrain dash & door panels).
The car has sat since the mid-1980's, however much to my surprise the body isn't that bad. It will need the usual quarter panel work, cabin floors, trunk floor and small patches on the rockers and fenders as well as a good bit of roof work from being a vinyl top car.
This car also originally had front disk brakes, the 340 K-member & front sway bar, which were all standard on a 1973 Dart Sport 340. It is a power steering car, and originally had A/C.
how much for the proportioning valve?
Would you please respond via message.
thanks!
I have 3 A-bodies I am currently cutting up, one of them will have what you need...
thanks!
$57 shipped
Great
FYI....piece I am looking for should be maybe 12" x 30" (?). The little bit of floor section can stay on....I will remove the spot welds
Need price shipped to 43402 (ohio)
Is 340 block available still? How much to ship to San Antonio zip code 78237? I have always wanted a 340. This is a good opportunity.
