JohnFM3
Ok, its not road worthy yet. But I had to see how it looks on the ground. The rear leaf springs are worn out. So I may need to consider lowering the rear once the new leaf's are installed. The other option I am considering is lifting the front end 1 inch. I need to get the car on flat ground and see where it lands to better judge what my next move will be. I have about 1.5 inch of spacing I can add to the rear tires. I will get pictures of it, and look for opinions later.
I need to fasten the shocks to the axle, shorten the drive shaft, install the steering column, and bleed brakes. I will be re adjusting the front suspension 1 more time before taking it to the shop for a alignment.
I am so happy. You would have to surgically remove this grin from my face.
