Blue dot tail lights are illegal on U.S. roads because federal law requires rear lamps to emit red light only. The blue insert alters the color, making light emitted more of a purple and conflicts with lighting reserved for law enforcement.What are the blue dots for, are they a legal requirement?
It's givin the man the finger. There's your simple, non BS unconvoluted answer. Dang John, make it complicated why dontchya? LOLWhat are the blue dots for, are they a legal requirement?
So was mine. Cliff noted. lolI do it well. But it is factual with historical information.
Gotta admit, it looks good. Turned out better than expected.So was mine. Cliff noted. lol
if the whole car's plumbed with flexi lines you will notice a softer pedal. i worked at a rally car supplies shop/warehouse and they discouraged customers from using all stainless braided flexi.Has anyone used or known someone who used stainless steel brake hose with AN-3 fittings in replace of hard lines? If so, how did it turn out? I have a neighbor who says its a bad idea as the hose bulges a little making the brake feel spongy.
Bummer. Its so hard to accept that as some of these lines can sustain 4000 psi as a normal operating level when brake fluid psi is under 1500 psi.if the whole car's plumbed with flexi lines you will notice a softer pedal. i worked at a rally car supplies shop/warehouse and they discouraged customers from using all stainless braided flexi.
neil.
First attempt was a failure. I am trying a new flaring tool by Titan. See how that goes. Bought my flexible tube kit from The Stop Shop. This job will be made worst by not being on a lift. We will see how it goes. Stainless an AN-3 fittings would be so much easier.i've always cut and flared my own hard lines using pipe on a roll. flaring tools that give nice neat flares are pretty cheap these days as are the fittings and pipe.
neil.
