JohnFM3
So I am finding out that it seems to be difficult to replace headlight and wiper switches. It maybe time to investigate modern replacements as alternatives.
I hope so.Most new balancers are marked correctly for one mark and wrong for the second. There are usually two marks on the new ones. One supposedly for each timing tab location, but somehow, the industry got one of them wrong and it's like that across the board from what I've found. I just used a piston stop, found true TDC and made a new mark on the balancer. Sounds like that's what you need to do.
Correct. Dead center of the two marks is true TDC. Keep in mind the more accurate you mark and measure, the more accurate your new TDC mark will be.I hope so.
Using a piston stop, I am guessing I bring piston to the stop, mark balancer, reverse crank till it hits stop again and mark, then finally mark the balancer in the middle of the 2 marks?
You're SO not paying attention.Ok, am I being stupid here....
I measured from the front edge of the rear tire to the wheel well at the bottom where the pinch weld ends.
Driver: 2in
Passenger: 1.75in
That tells me the rear axle is not tracking straight by 1/4 inch.
I am curious about the leaf springs, and whether they are the same or not.
Not sure what your talking about.... As I agreed and am working on resolving the rear end. As well as make corrective actions to the front and rear independent of each other getting them square to the car and not to each other. Meanwhile I am working on other items.You're SO not paying attention.
You were shown all the correct measuring points in that diagram that was posted earlier, yet you march on measuring from all the wrong places. You cannot measure from body panels and pinch welds. The car has dedicated measuring points in the frame rails that the diagram clearly points out. I wouldn't touch it until you get it on someone's alignment rack that knows what they're doing OR on a frame machine.Not sure what your talking about.... As I agreed and am working on resolving the rear end. As well as make corrective actions to the front and rear independent of each other getting them square to the car and not to each other. Meanwhile I am working on other items.
If you make note of the time stamp, that post is much older than the other thread.
I know I was, and I am very grateful. It was really a learning experience. I didnt know the front leaf spring mount was removable from the car, allowing for shimming to be possible. I agree. I am trying to postpone rear work until I can afford new leaf springs including mounts, shackles, and bushings. Rear springs, mounts, bushings and shocks will be close to $1,000 for everything I want to go thru the whole system. And once that work is done, I will use the diagram to measure my chassis measuring points to rear axle for a rough starting point. Then get a job, followed by taking the car in for front end work and alignment.You were shown all the correct measuring points in that diagram that was posted earlier, yet you march on measuring from all the wrong places. You cannot measure from body panels and pinch welds. The car has dedicated measuring points in the frame rails that the diagram clearly points out. I wouldn't touch it until you get it on someone's alignment rack that knows what they're doing OR on a frame machine.
$7-800 is a lot of money compared to your time spent picking the loom apart and replacing any damaged wires. especially if you don't have that kind of money laying around right now
neil.
