[SOLD] 1974 Dodge Dart Swinger
chrisdcuda
F O R S A L E
1974 Dodge Dart Swinger 2 door Hardtop
This was originally a SC car that was bought by previous owner and relocated to Georgia. This owner did a lot to the car but ended up having a heart attack and sold the car to his son-in-law and moved to FL with his brother. The son-in-law sold me the car some months later. The son-in-law did not know any background on the car, and simply gave his father-in-law money for the car to help him out. It was a factory vinyl top car that the previous owner had removed, with no apparent rust through. I have all of the top trim to put back on if that is what someone would want to do. Personally I like it better without the top. All of the pans are in good condition and I don't think need replacement. I have had the car finishing things that needed to be done as I had the time and funds to do so for 2 1/2 years now. My wife of 52 years passed away last June unexpectedly and I am simply trying to get done all of the outstanding things I need to finish up so as not to leave a bunch of loose ends for my daughters and grand children to have to deal with.
. V8 318 w/Edelbrock 4 bbl. Aluminum intake and Carburetor
. 904 3-speed Automatic Transmission
. Power Steering
. Power Front Disc Brakes (new Master Cylinder and Calipers)
. Factory A/C system all intact with nothing missing, needs re-charge
. Dual Side Chrome remote Mirrors
. Fender Mounted top Turn Indicators
. Big Bolt pattern 4.5 inch Rallye Wheels w/Acorn Centers and SS trim rings
. Dual Snorkel Hood Scoop
. 8 ¼ Rear Axle
. Headers to straight pipes with no mufflers, but do to the length are not too loud with chrome tipped pipes
. Factory Vinyl top car has been removed by previous owner, have all of the trim if to put back
. KY4 Golden Fawn paint
. AM working Radio
. 3-speed Wipers currently motor bad, do have a replacement to go with car
. New factory style carpet installed
. New Fuel Sending Unit
. New Spark Plugs, Wires, Cap, Rotor
. 89,000 original miles (which looking at the odometer all of the numbers are straight across with no mis-aligned digits, so I believe this is the first time around miles, and the pedals don't appear too worn, but I can not prove that assumption)
. New Voltage Regulator
. Has original factory jack, base and lug wrench
. Simulated Wood Grant Steering Wheel
Currently not insured or tagged and can not be driven on the street. Bring a trailer. Can hear it run and check transmission function. Do have a Clean Georgia Title in previous owner name, already signed over (undated). This is a solid car with no pans needing to be replaced. Straight body, needs repaint. Heater core leaking (bypassed now) and needs replacement.
Price: $9,500
Any interior pictures?
Any pictures of the undercarriage?
Is that rear stripe painted on, or is it removable?
Do all interior gauges/lights work properly?
Any rust on exterior panels?
Thanks
Thanks
Other than the picture of the dash showing the odometer I do not have any. The front bench seat needs recovering primarily in the driver's position, but the read seat is in good condition in tan. I have replaced the carpeting with an OEM version from the carpet folks in AL. I was limited to only 10 pictures of the car on this post. The car has a solid underside with only here and there surface scaly rust, but no rust through that I can find anywhere. The stripe from the factory is a decal, but some of it on both sides was worn so I painted the two sides for completing the look. All of the lights both in and outside work, including the flashers. All gauges work as they should. The exterior of the car has no rust through and I have only spotted some very small bubbles in only a couple of locations.
