1974 Duster with manual disc brakes
Valleyant
Valleyant
Cincinnati, Oh
Hi,
I have a '74 Duster that was ordered with the manual front disc brakes. It is a very low mileage car and I'm getting it ready for good weather driving this up coming Spring. The problem is that the rear drums lock up the rear wheels with anything more than slight pedal pressure. Theres no leaks in the system (master cyl is full) and the brakes work, just with an unwanted screech from the rear tires....Any help appreciated! thanks
Did you pull the rear drums and check for wheel cylinder or axle seal leaks ??
I had the same problem with my 74 and found both sides were wet from leaks.
All new parts and adjusted work as good as manual brakes ever did.
Just my 2cents.
