[SOLD] 1975 Dodge Dart 2-door HT
Rick@Laysons
FABO Vendor
FABO Vendor
Lakewood, WA
1975 Dodge Dart 2-door HT, converted from slant six to 318-4bbl, also converted from column shift/bench seat to floor shift/console with bucket seats.
Body is SOLID!!! Has a few parking dings, but no major dents. Some minor bubbling is starting to show under the vinyl roof.
Interior is nice red velour......
Car starts, runs, drives, and is available for up close inspection and test drives. If serious about purchase when you're here in person, we can even put it up on a lift and let you inspect the underside as well.
This is the "sleeper" to be sitting at a stop-light with!
Price is $4000 FIRM! No haggling...no trades....this is a "turn key" car that needs nothing to be drivable and licensed. All lights and signals function properly.
It is the original paint, even has a couple of untouched dings.
The most obvious one is up front by the headlight on the passenger side.
Mechanical specs.......I have the receipts for all of the following items.....
'72 318
TRW 9.2 comp. forged pistons
Direct Connection(DC) cam, 272 duration, .455" lift, 48 degree overlap, part# 4286671
DC double roller timing set
DC heavy duty rod bolts
DC high volume oil pump
Edelbrock LD340 intake
Edelbrock 600 cfm carb
360 heads, 1.88" intake, 1.60" exhaust
Bronze valve guides
rotating assembly has been machine shop balanced
7 qt. oil pan(8 quarts capacity with oil filter included)
Windage tray
Manual Disc brakes
Rebuilt Power Steering pump
Rebuilt Power steering box(Firm Feel...police specs)
Rebuilt front suspension
KYB shocks
A-body 8 3/4 rear end, REBUILT clutch type Sure-Grip, 3:55 ratio, new Moser axles w/new wheel studs
340 Hi-Po exhaust manifolds
New 2 1/2" dual exhaust w/Dynomax mufflers
Rebuilt small-block 727 transmission
Car also comes with a trunk load of extra parts.
