1975 Scamp inside door handle assembly
roadrunnerh
Pittsburgh, PA
Hello, I am in need of the inside door handle assembly. When I open the door from the inside, it opens but the handle does not snap back as it should. It's no longer spring loaded, I see the spring but it's moving freely.
I can not tell which part I am missing so I need the assembly. Left Side / Driver's Side.
Thank you for the response, but it would have to be '73 and up. The 72 handle is different. This one is high up on the door, the 72 is lower and different in appearance.
I might have a passenger side but I know I don't have a driver side. If you can't find a pair, let me know and I'll check for you.
Thanks, Mark
IF ANYONE HAS A SECOND ASSEMBLY I AM IN NEED OF ONE AS WELL! SAME PROBLEM! AHHH!!! Good luck finding one to you as well my friend. I have literally been looking for the same thing for 6 months....gah.
