So I have an opportunity to buy a 1977 Plymouth Volare for cheap, I was wondering if I could use the front brake system on my 1968 Dart?
Any info will be appreciated.
Yes you can, right down to the prop/dist valve block. Just not the UCA's or LCA's.
As Joe said you'll need large ball joint UCA's, or you could get the upper balljoint adapters from DoctorDiff. Lower balljoint is 73-76 A body (drum or disc, both are the same)
Dont forget to grab the rear brake assemblies too...10"x 2-1/2" drum brakes on all F bodies. They work great if your going large bolt pattern on the rear.
