HemiSSDart
Dartus Interuptus
1984 Dodge D350 crew cab dually with 91 intercooled Cummins diesel and 727 with gear vendors overdrive. 4.10 Dana 70, newer tires on Alcoa aluminum rims, heavy duty rear tow bumper, 2001 front seats, full gauge package, brake controller. A/C is installed but not charged, fuel gauge does not work, cruise installed but it also does not work. Newer tires, 5" exhaust to dual chrome tips, stainless full-length running boards, custom paint. No rust but body is not perfect, used to have a roots blown 440 in it before the Cummins install. Fiberglass cap painted to match, hole in bed for gooseneck but does not come with gooseneck unit. Only other annoyance is the master cylinder leaks down at stop lights but pumps up fine, will probably need a new master at some point. Blaupunkt AM/FM CD with extra rear speakers. Will tow anything you want it to! $10,500 obo located in Rockford, IL.
