[FOR SALE] 1991 Jeep Cherokee 4wd 5 speed
Dustert73
Stripping bolts since ‘10
Ohio
1991 Jeep Cherokee 4 door, 4 wheel drive, 5 speed, 4.0 high output strait six, with 236,302 miles. 1 owner (my parents) since '91 with a clean title. I can tell you all the maintenance that has been done to it since new. Body and frame is rusted out and the interior has been stripped, so it's pretty much just good for the drivetrain which you can use to convert your jeep to a 5 speed. Then you can scrap the rest to make some of your money back. Doesn't run (getting no spark to plug wires), but does turn over. Was running and driving fine around our property with no knocks or grinding before it quit. Will need to be towed. From what I can see it has a dana 30 in the front and a dana 60 in the rear. Good tread on tires. Asking 800$. I'm not into parting out sorry. If you look around the ole interweb's you will see the drivetrain alone is worth more than that. Located in Granville, Ohio 43023. "Hood scoop" comes with it :wack:. Private message me if you have any questions. Thanks FABO!
