1. Arnie Torres
    Arnie Torres Member
    5
    0
    Dec 2, 2019
    Texas
    Local Time:
    8:33 AM
    Hello i have a 318 out of a 1991 ram that i need a standalone for. Got truck as an unfinished project and would like to get it running. Anyone know where i can get one, it needs to be for engine and auto trans?
  2. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
    3,326
    986
    Dec 27, 2013
    PHX
    Local Time:
    6:33 AM
    eBay.
    Jake
  3. Stephen Hotz
    Stephen Hotz FABO Gold Member FABO Gold Member
    1,764
    1469
    Dec 30, 2017
    New Braunfels, Tx
    Local Time:
    8:33 AM
  4. TT5.9mag
    TT5.9mag Two atmospheres are better than one
    153
    148
    May 5, 2016
    So cal
    Local Time:
    6:33 AM
    Currently there are zero standalone plug and play systems available for a magnum. You can make a megasquirt system work but if you are leaving the engine stock it’s not necessary. Just run the factory ecu and efi.
  5. diymirage
    diymirage HP@idle > hondaHP@redline
    17,199
    10443
    Oct 12, 2012
    michigan
    Local Time:
    9:33 AM
    just convert it to carb and run it
  6. DionR
    DionR Well-Known Member
    1,936
    201
    May 7, 2008
    Spokane, WA
    Local Time:
    6:33 AM
    Just so you know, that motor isn't out of a '91 Ram. It might be in one, but that is a '92-95 5.2 (318). The '91 would (I think) have been TBI and that motor is a Magnum that wasn't released until later.
    Maybe you know that, just didn't want you to get tripped up trying to getting it running because you had some incorrect info. Just trying to help.
    • Agree Agree x 1
    • Arnie Torres
      Arnie Torres Member
      5
      0
      Dec 2, 2019
      Texas
      Local Time:
      8:33 AM
      Ok i was told motor was out of a 1991 due to serial info on computer so thanks for setting me straight. I have this engine in a late 60s truck i got that way as a project that never ran due to harness not squared out. It has the transmission attached to it from that same 90s vehicle. So i am just trying to get it running without braking bank.
    • DionR
      1,936
      201
      May 7, 2008
      Spokane, WA
      Local Time:
      6:33 AM
      I would argue that the cheapest way to get it running is to finish the Magnum swap someone else started. I would start by researching "Magnum swaps" and see if you can figure out what is missing.
      Second idea is to try and swap a carb onto the motor and get rid of the EFI. It will probably mean you will have to control the OD transmission manually or get some pressure switches, but not an impossible job. That is assuming you don't have a '96 or later motor with the electronically (RE) controlled transmission in which case you pretty much need to keep the PCM.
      Your info on the computer would suggest you have a hydraulically (RH) controlled trans, but probably best to verify first.
    • Arnie Torres
      Arnie Torres Member
      5
      0
      Dec 2, 2019
      Texas
      Local Time:
      8:33 AM
      I guess i need to try and find a wiring diagram to see if i can figure out what was done or missing. Alot has been done to truck just wasn't started due to previous person not having idea how to get wiring situated. I will get under truck and look at trans and see what's on there. Thx?
    • Bobzilla
      Bobzilla Well-Known Member
      618
      427
      Aug 10, 2017
      Livonia, Michigan
      Local Time:
      9:33 AM
      Are the ECM connectors on the harness that is in there, that is currently connected to the engine?
      Does this engine have an EGR valve at the rear of the intake on right side?
      Can you post a picture of the ECM you have showing the connectors?
      OBD1 will have a single large connector. OBD2 will have three smaller connectors.
    • Arnie Torres
      Arnie Torres Member
      5
      0
      Dec 2, 2019
      Texas
      Local Time:
      8:33 AM
    • Bobzilla
      618
      427
      Aug 10, 2017
      Livonia, Michigan
      Local Time:
      9:33 AM
      Definitely OBD1. Not programmable but easy to use as a stand alone.
      How about EGR valve as asked previously?
    • JDMopar
      JDMopar Well-Known Member
      2,478
      1275
      Jan 19, 2012
      Candler, NC/Myrtle Beach, SC
      Local Time:
      9:33 AM
      Arnie....since it is OBD1, I just remembered something that might help you. There is a member here that used to convert the Magnum OBD1 harnesses for people, at a reasonable price. His user name is 393foureyedfox, if you want to shoot him a pm to see if he still does it. He was last online here in June of this year. I'll tag him so maybe he will get a notification and see this. @393foureyedfox
    • Arnie Torres
      Arnie Torres Member
      5
      0
      Dec 2, 2019
      Texas
      Local Time:
      8:33 AM
      Thank you, i had tried reaching out to him via email but no luck yet. Thank you again.
    • JDMopar
      2,478
      1275
      Jan 19, 2012
      Local Time:
      9:33 AM
      You're welcome. He's not on here much, but if he gets thread notifications maybe he will jump on to see what's up. Good luck. :)
    • vegasanthony
      vegasanthony Well-Known Member
      107
      25
      Aug 19, 2014
      las vegas
      Local Time:
      7:33 AM
      No longer in business from what I understand . Hotwire.com the only way to go here
    • JDMopar
      2,478
      1275
      Jan 19, 2012
      Local Time:
      9:33 AM
      :( :BangHead:
