HemiSSDart
Dartus Interuptus
1992 Dodge D150 LE shortbox with the 3.9 V6 and 5-speed trans. Is an LE model so it has factory A/C, power steering and brakes, cruise control, runs and drives but will need some work to become daily driver. Has power steering and radiator leaks, have not tried the A/C. Drivers door was replaced but wiring had been cut to the power windows and locks, used complete harness comes with. Both rockers had rust through so reproduction rockers were welded in properly and primered, obviously needs paint. No other rust through has been found, though there is some surface rust and a few dents/dings. Good tires/wheels and comes with extra parts including a nice grille. $3300 obo can drive home but drivers window does not roll up due to wiring issue mentioned above.
