DroVal
1994 Camaro Z28 T-Tops $2500.00 OBO 5.7 V8 and Automatic
Will also consider Mopar trades, must be DD quality at least, no projects.
Located in Mesa, AZ. This is a 2 owner vehicle. My Aunt bought it new. It is originally a California car. Was brought here 3 years ago (Roughly). Car has 176k miles on it and motor was replaced at 116k (unfortunately I have no paperwork to prove this). My Aunt was very good about regular maintenance and left me with plenty of receipts to show it. It also has the original owners manual, build sheet, and some of the original warranty paperwork. Have clean AZ title. Car runs strong and I would not hesitate to drive it anywhere.
Overall this is a great car. It has some cosmetic issues and a few other small issues, but nothing serious.
Recent work done:
-Yokohama Tires with 1700 miles on them
As of 7/30/2013:
-New Fuel Filter
-Airfilter
-Rear brake Pads
-Rear shocks
As of 09/10/2013:
- New Valve cover gaskets
-New transmission mount
- Cooling System flushed
-Oil and Filter change
-New coolant line gaskets and compression fitting (to repair a leaking factory hard cooling line)
-New coolant expansion tank
-New intake gasket
I have receipts for all of the work listed here.
Issues that I know of:
-Original stereo cuts in and out when going over bumps in the road (volume control knob is messed up)
-A/C works, but does have a leak and will need to be recharged from time to time if it doesn't get fixed
-Since the mount was replace the trans shifts a bit hard from 1st to 2nd gear, but it has never given me any trouble.
-Paint is faded and clear coat is peeling on hood and black area around the T-Tops
-T-Tops do have a small leak on each side
-Sun visors were removed. I started to prep them to be recovered. Have both visors still.
-Power windows work, except the driver side needs one of the track guide wheels replaced.
-rear main seal has begun to leak, but not a big leak
Resizing pics, will have more uploaded soon
Recent work done:
As of 7/30/2013:
-New Fuel Filter
-Airfilter
-Rear brake Pads
-Rear shocks
As of 09/10/2013:
-New intake gasket
