onehellofadart
Well this was my first season trying to get back into racing in about
30 years. Got my car out of the shop in May 04. 1st time out ran a
disappointing 14.883 @ 95mph. It was all me. After months of
adjustments (mostly to my technique) and questions I ended the year with a 13.212 @ 104.19MPH. Modifications along the way were New msd distributor,6al box , blaster coil, and finally after fighting it for 6 months screwed the tires to the rims.
Part of the problem was my misconception of the weight of this car with my a$$ in it. At conception I believed the weight of the car with me in it was going to be 3100lbs. Turned out to be 3500lbs. I wanted the best of both worlds and argued I only wanted 3:91 gears since it was 90% street car. I should of listened but didn't since I don't do that much distance travel with it anymore.
All in all I did manage to drop et 1.671 seconds and gain 9.19MPH. You have all heard my problems along the way and I thank you for your help here at NEBR also at FABO, and Mop/Tech. Over the winter I am going to install a Hurst pist Quart stick, Cope rev valve body and 4:30 gears, may also go for a bit more stall.
I am def looking forward to next season and hope to be way down in the 12's . Of course then I will be crying about how to get into the 11's. The bug has bit me and bit me hard.
