Notanova73
Add says you can go up to 488 with itHow do you know what gear ratio it's for?
Ok cool you had me stressing for a second haha.that’s what I was trying to ask earlier if there were differences I wasn’t sure about but no it’s 27 spline pre 96 add states 308-488 it’s prob out of something newer I guess they take em apart and go through them it’s only 200 but it’s on a bid on eBay I’ll prob go to junkyard tomorrow to scavenge but the mopar pickings are pretty slimWell there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
Yeah no luck at junk yard 2 more hours before bidding ends on the sure grip I showed you if I wasn’t changing gears to 410 I’d buy the other oneWell there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
At least they took it apart to inspect it.Well there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
before it’s too late what else in the other one would I need vs this one?im buying new gears and install kit with bearings.Well there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
What are these?Well there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
well I won it lolWell there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
$226 after shipping and taxWell there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
Spry for opening same post over and over but you haven’t responded only with likes , I gotta put this rearend thing on hold because I only have a little more money to spend and since I already have the correct suregrip I gotta get a high stall convertor and redo rear latsr thanks for the helpWell there you bees. I still like the other one better. Much better deal for not much more money. It has everything and then some.
Fuk it lol I’m done with 245 gearsAt least with the 2.45's, you don't need an overdrive.
YeahNow the one you got was just the sure grip carrier, right?
I can relate to doing things one piece at a time.
Do you know anything about the closed chamber 302 heads? Since they came from a roller engine the regular pushrods from a pre roller 318 should work right?
302 heads are same as 714 I believe they come with both oiling passagesI'm not sure of they are the same pushrods or not. The LA and Magnum blocks have a different deck height so purhrods might be different. If you can find 302 heads uncracked,they are pretty decent for a 318.
Both la engines just the 302/714 areI'm not sure of they are the same pushrods or not. The LA and Magnum blocks have a different deck height so purhrods might be different. If you can find 302 heads uncracked,they are pretty decent for a 318.
the stock la 318 my car came withYeah but you're still unclear about WHICH engine you have.
Sorry I’m having issues with my phone it went to an Amazon thing while I was typingBoth la engines just the 302/714 are
