:wave:
Spring is here and I am thinking of swapping a 2 barrel intake and carb I have sitting on the shelf into my 73 Duster with a 3 spd manual trans.
Can I use the same throttle cable that is in the Duster? (original 1 brrl 3 spd manual)
I know that a kickdown is not needed but are the throttle cables the same between 1 brrl and 2 brrl's?
I ordered the intake gasket and will probably do the swap this weekend.
Thanks for your input!
