2 batteries
Ken Blackman
Blacks1971Duster
12094 Wellington Road St.
I,m installing an electric fan and water pump in my 1971 Duster, 360 cid drag car ( mid 12 seconds). I want to install a second battery, do I install the second battery by connecting the positive to positive and negative to negative ( parallel ) and what size wire should I use to connect the batteries.
Thanks
Ken Blackman
I don't see any reason to run two batteries in these cars. Nowadays you can buy INCREDIBLY powerful auto batteries, most of which are overkill with most street engines
What engine combo, HP are you running?
AND it's "not the battery" that is needed to run big stereos, fans, etc, it's a larger alternator, and you do NOT want to try that with factory wiring, the factory bulkhead connector, and the factory ammeter
Please READ this article, which details a few of the problems:
Generally,
not a large enough alternator, nor do the factory originals put out enough at lower rpm
not large enough wiring
the bulkhead connector was NEVER designed to carry much amperage
the factory ammeter has it's own problems
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
which came from here:
http://www.madelectrical.com/electrical-tech.shtml
Thanks
Ken Blackman
Hello Ken, you run + to + and -to -, this give you still 12 volts, but 2x the cranking amps, use typical battery wire, same size/gauge from your starter, ground, etc. 6 or 8
Hello: Tribute SS/A 68
I'm not looking for more cranking amps. just more battery storage capacity inorder to run electric fan and water pump when I get back to the pits. If I get 2X the cranking amps is the chance this will burn out the original wire in the car? ( such as the factory bulkhead connectors)
Ken Blackman
The cranking amps do not put any extra load on your wiring, they give you more reserve for cranking. This reserve is storage.
Grant
Grant
Actually, if you have the typical factory stock Mopar ammeter/ bulkhead connector wiring, it CAN strain the wiring, because two big "high cranking amp" batteries can behave with a lower charge impedance that a single, smaller battery.
If you try and compensate with a larger alternator and the factory wiring, you are inviting trouble. Time to read the MAD article on the subject:
But you MIGHT want to read the race rules now that we know what you are after. I believe NHRA only allows ONE battery in some classes, but I could be wrong.
From the 2011 rulebook:
"A
maximum of two automobile batteries, or 150 pounds combined
maximum weight (unless otherwise specified in Class
Requirements), is permitted"
