2 questions
Tadams
Tadams
nc
My /6 had a 1 barrel and was replaced with a 2 before I bought it. The manifold wasn't changed so the choke will not hook up. Where can I buy one or do I need to purchase a new manifold? Second There are 2 springs that hook up on the side of the carb. It has an automatic and I can't remember where they go. Can you guys help me. Car is a 65 barracuda that I am restoring and not driven but am making progress.
Thanks so much for your help.
Thanks for info. Mine has an automatic trans and there is another spring that runs toward the rear of the motor. Also the choke I have Is suppose to fit into the exhaust manifold. If I bolt it that way there is no way it can hook to the carb.
