then I wouldn't buy or add anything till you solve the current problem. Never mask an issue by compensation.Your truck would stomp the guts out of mine
75-80 mph is going to kill gas mileage. My 2wd 3/4 ton gets 18 at 55-60 mph. That's some small town driving along with commuting to work or wherever. I have 3.55's, automaticCan you guys all provide more vehicle info?
What gear ratios, transmissions, speeds the fuel mileage is veing judged, and what octane fuel and alcohol content of fuel in your area for these mileages you are getting?
My first 1999 Ram 2500 with 5.9 Magnum has 4:10 gears, four wheel drive, overdrive auto trans, and larger than stock tires. This truck always about 11 mpg at 75-80 mph speeds, and would barely reach 13 mpg at 65-70 mph.
My current 1999 Ram 1500 with 5.9 Magnum also has four wheel drive, overdrive auto trans, larger than stock tires, and I think it has 3:54 gearing. This one gets 13 mpg at 75-80 mph speeds.
My old 1993 D250 with 5.9 Magnum is two wheel drive, overdrive auto trans, 4:10 gears, stock tire size. That one never did better than about 14 mpg at 75-80 mph.
All my trucks have run regular unleaded when not towing, which is usually 87 octane with 10% alcohol here in Michigan.
correct. With 35's, he killed gearing, and he is actually going further than the odometer said. Mine has factory LT245/75/16 - not sure of height, must be about 30"As long as you have a heavy 4x4 truck with 35” tires and are hauling a load, you’re not going anywhere quickly or with good fuel economy. You could put a 400 hp crate engine in it and it will be a dog without a torque converter and new gearing.
How are you calculating your fuel mileage? The only way is by getting mileage by gps and measuring the fuel that goes in. Using the odometer and topping off the fuel tank is a wild guess with bigger tires.
