2017 ram 2500 broken manifold bolts
Why does the aftermarket header bolts not break, but the stock one do today. I still say the steel in the bolts used today are inferior. When I commented on lowing the Torque, I didn't mean loose, just take a little pressor off the bolt and allow the gasket to take up some of the expansion. Just like piston rings, they need to expand a little or they break.
Back to the bean counters again. If they can save 1/10,000th of a cent per bolt times millions of exhaust manifold bolts per year, the bean counter justifies his/her position.
Recalls don't save money. A five cents bolt may cost the manufactor hundreds of dollars for repairs, plus a customer in the future. Save me now, I'll pay later, attitude!!!! A bean counter can save a company money or close them down.
So now a hypothetical scenario, The manufacturer decides to put the manifolds on with 3/8 grade 8 bolts now, to cure the problem of 5/16 low grade bolt snapping. The 3/8 bolt cost more but is much stronger, so now that bolt pulls the threads out of the aluminum head instead of breaking. How much is that going to cost in warrenty repairs?
It all come down to the almighty buck and which solution keeps the prophet margin the highest.
The engineers, bean counters, and management, I will bet will all vote to keep using the weaker 5/16 bolt.
That is why you have torque specs. The threads on a larger bolt as you say, should also make the threads in the aluminum heads stronger to hold. Just follow the torque specs and no stripping out the head or breaking a weak bolt.
Youse is overthinking da sityatun. Why do you introduce Gr 8 bolts? 9mm 8.8, 10mm 8.8 or 3/8 grade 5 bolts would be fine. IMHO the breakage is not from tension expansion of the manifold. Those bolts get plenty warm through heat convection from the bolt head in contact with the manifold. My belief is that the manifolds expand lengthwise putting a bending stress on the bolts. Hardened washers with antisieze between them and the manifold to aid slippage along with the larger diameter bolts that have the strength to resist the bending forces is the cure.
I really doubt that if the threads have the correct engagement they will not pull out of the Al heads.
It goes all the way back to the slant 6 and possibly prior. They have special washers that basically act like a "spring" and allow the manifold some "wiggle room" if you will for expansion with heat.
What they should have done was put studs and nuts on instead of bolts.
Now my question is which bolts have the higher shear strength, a gr-2, gr-5 or gr-8?
On the subject of studs and nuts, the GM LS engines and the Ford Mod engines both use studs and they are both having the same cast iron exhaust manifold attachment breakage problems as the new Hemi that uses bolts.
Guys, please do not interpret me as an overly educated man, I have alway been just a hard working blue collar stiff. I learned everything I know in my 70 years through practical experience, and from asking questions and listening to those with experience.
with all manufacturers. It seems worse with Ford (that figures)
LS gm are horrible ford V8 are very close 2nd.
Hemis are distant 3rd .
I do about 10 broken stud/bolt repairs a week.
Last week I did a Ford 390 which all the bolts were broken lol, that was fun
My truck developed a little exhaust leak when cold, and sure enough, it sheared of a few exhaust manifold bolts on the passenger side
Just to confirm with you guys...this totally justifies putting long tube headers on, right?
Absolutely, 1 broken exhaust bolt means.... legally you must replace the logs with long tube headers lol.
I say, the start of a broken bolt is when you insert them into "WHATEVER". I always add a little anti-siege when I install some as the water pumps and timing covers, wheel studs or any other locations that seems suitable. I no they make a high temp sealant for the exhaust, but not sure on an anti-siege.
i know for a fact there were at least 2 broken bolts (4 if you count the pieces) so im glad i put the headers on
I anti seize them too, dissimilar metals doing their thing always makes for a fun bolt removal
Yes, the washers are like ththick Belleville washers and appeared to me to be of a hardened construction. The Chev 'liners had similar washers.
Everything engineered over the last 30 to 40 years has used metric measurements. Stepping up from the 5/16" or 8mm bolt or stud size to 9mm would be a vast increase in strength. Combine that with the conical washers and the bolt breakage would be pretty much elliminated.
Two qualities to discuss; tensile and shear.
As the bolt grade increases the tensile strength increases through chemistry and heat treatment. This increased tensile strength provides higher clamping load, but at a cost, Shear strength. A gr 8 bolt will break in shear while a gr 5 or gr 2 bolt will tend to bend.
Hope that clears that up some.
Yeah but then they might have to spend a little money. God forbid.
And the win goes to Dale Davies, Thank you!
You wouldn't believe how many people will argue that the gr-8 shear strength is greater because the bolt is stronger.
What is the source of shear load on the bolt in an exhaust manifold application? Considering the bolt is torqued to spec into a through hole with about .020" radial clearance, there should be nearly no shear or sideways force on the bolt, it's all in tension, no? Any force coming back from expansion of the pipe system that might cause shear would be absorbed by the mounting system and pipe deflection and anything else would be shared across all the bolts in the manifold. How significant could that force be?
I the manifold is resting against the bolt when it is tightened, expansion and contraction of the cast manifold can cause the shear force. Another related to shear is the bending force as the bolt head sticks by friction and the clamp load. As the manifold expands and contracts, it slides against the head or the gasket. Of course the thread goes nowhere, so the bolt flexes at the exhaust surface of the head. This is really a fatigue failure, but related to the shear as it is not tension related.
Nothing in the rest of the exhaust piping has anything to do with manifold bolt failure, it is all in the manifold and the bolts.
I agree that the failures are mechanical/thermal fatigue related, but I don't see any potential for a shear component. The major forces are acting on the z-axis of the bolt, not shear in the x-y axes. It's a moot point really. The fastening system isn't reliable enough and either didn't go through accelerated life testing, or the results were not properly acted upon. Just like all of us, these companies make their choices and take their chances.
Raising this one from the dead.
@diymirage can you give an update on how the headers are working out for you? Would you happen to have a pic of how the Y-pipe fits around the transmission? You have to drop the trans pan to change the filter and the access to the drain/fill plug is not great to begin with.
I've turned 110,000 miles on my 2020 and one or both sides are definitely leaking. Haven't dug into seeing how bad or how many bolts are broken, but I have little hope that the dealer will cover anything but I will check when I get a chance. I thought I read on a Ram forum that they had improved the manifold casting but that wasn't verified. If I'm going to have to pay for the repair, I'm not going to put the same crap quality parts back in so the AHR headers are a strong possibility.
Anyone had to deal with this lately on a truck that was past the 60k warranty?
I bought a '21 1500 5.7 Ram 2 years ago. It was a mfr buy back, overheating issue. Still had the problem, asked for a new engine under my 1 year unlimited warranty. So, got a Mopar reman engine out of it. The three problems that I was aware of after purchase were, intake manifold bolts, cam&lifters and broken exhaust manifold bolts. I only have about 10,000 on the engine now. My approach has been not to jump in it and go, rapid heat up. Warm engine at 1,000 rpm till 150 ° or so before I drive it. Will see if this helps the exhaust and lifters issue. Seems like I can retorqe the intake almost every time I drive it. Tried new bolts, same. They are not loosening, I marked them. So it's probably the plastic intake. I just check them once in awhile now, and try keeping them at 50 in lbs instead of the 108. My fuel mileage came up when I first checked them. It about 21 mpg now, 3:21 gear.
