intergalactica
- Joined
- Dec 16, 2006
- Messages
- 416
- Reaction score
- 30
Yesterday I ordered some BFGoodrich 215/65/15 tires at Summit racing.
Will these fit properly on the front of my '67 barracuda? Any fender rubbing whatsoever?
Here are the specs...
*Note the .10 inch increase in overall tire diameter and the .60 inch increase in tread width.
The ones I ordered:
P215/65/15 BF Goodrich Radial T/A (Summit Part #BFG-78624)
*Tire Diameter: 26.00 in.
Section Width: 8.70 in.
*Tread Width: 7.00 in.
Load Range: 95
Minimum Recommended Rim Width: 6.00 in.
Maximum Recommended Rim Width: 7.50 in.
Max Load Single: 1,510 lbs.
The ones I currently have on my car:
P215/70/14 BF Goodrich Radial T/A
*Tire Diameter: 25.90 in.
*Tread Width: 6.40 in.
Load Range: 96
Minimum Recommended Rim Width: 5.50 in.
Maximum Recommended Rim Width: 7.00 in.
Max Load Single: 1,554 lbs.
I'll be installing them on new Cragar S/S 15x6 wheels with 3.375" backspacing (small bolt pattern)
What do you all think??? Too big...too wide???
The ones I ordered:
Load Range: 95
Load Range: 96
