[WANTED] 22 inch early V8 A fan shroud
Are you looking for just the fan shroud or shroud and special brackets/hardware?
I am looking at a radiator with a shroud on it and those mounting bolts look like generic hardware bolts. I pulled out a set of OEM brackets, bolts and clips I had powder coated and the bolts are typical Chrysler with the lip around the head of the bolt. In other words the center of the bolt is recessed. Looks like either will function just fine.
sent from my iPhone
sent from my iPhone
So do you have one?
