[WANTED] 22'' Radiator and Shroud
The radiator opening for a 64 is 19 inches and a 22 incher will be partially covered on the right side by the side support unless it's been opened up and new mounting holes drilled or swapped to a 65/66 RH side support. If you're still looking for a 22 incher, how about one recored to a 3 core? Can't help you on the shroud for a 22 inch right now - possibly later this winter.
To be honest, I'm just looking to replace the original 6-cylinder rad (18x19'') with a larger unit because my 318 is overheating. Also need to channel the air through the rad with a shroud. I can wait. Car is under cover for winter. Just thought I'd get a jump on Spring. Let me kbow when you find/get something that works for my application. BTW-It's a 4-speed, no AC. Thanks. .content://media/external/file/10253 Already out in a 160 thermostat.
I do have a 22” V8 radiator that I had recorded to a 3 core for a 65 Valiant convert. The ‘vert was going to get a 340 4 speed, so there’s no trans cooler in the bottom tank. I’d recommend either swapping the 65 passenger side panel or cutting yours to take full advantage of the size of the radiator. You have a good core support to hood seal and a cowl to hood seal? They’re important to direct air flow through the radiator.
Core support is very good. How much are you asking for your radiator?
