22"
Her1970
Tipton, IN
Few questions.
1 If I keep the 22" radiator where can I find a smooth upper rad hose. I can not stand the ribbed one. Hometown NAPA and Autozone cant help me.
2 Should I ditch the 22" and go with 26" and if so, what will bolt right in?
FYI cooling a 360 for street use.
Do you have the same setup I currently have? 22" with upper on Passenger side?
No I have a 360 with the hose on the drivers side. What year had the hose on that side? Is that a a-body radiator?
I believe that is a Slant Six Radiator. Try a Slant Six Upper Hose and see how that works for ya!
Later,
Bruce B.
One of the formed hoses on this Autozone page may well work for you (such as L-125). They're all for small blocks:
http://www.autozone.com/autozone/ca...&navValue=16300775&itemId=775-0&parentId=63-0
Look for A/C applications. There's no reason you can't use the 22" rad with that 360. I'm using a 3 row 22" unit for my 440. Upper hose is in the same position. I used a formed upper hose for a big-block B or C body application and had to shorten the hose.
Not sure what year. I know slant six hose comes straight out and is much shorter.
1970 Challenger 440 1970 Road Runner 440
AutoZone Part# S-105 $9.99
Oreilys Part# Gates 20630 $14.99
The 22" Radiator is the biggest factory Radiator you can fit without cutting the Radiator opening.
Stick with the 22" with a shroud, youll be fine.
