I have leaned in the past that there is many MANY different / dip stick tubes
I have seen some under 5'' long 6pak, and some well over 12'' long.
I have seen many threads and seen one myself where the dip stick hits the crank and brakes the tip off, What I did with mine was after a 5 quart oil change I made my own dip stick, I had to cut about 3 to 4'' of and make me a full mark with a file about 1 full inch from the bottom of the replacement dip stick, so it would be possible to pick out what tube length would be best for you VERY cool /6 you have going on :thumleft: sorry so long winded 6pak :toothy9:
